quik question on covering DD
Well I am about finished with my DD. All I have left is to cover the wing tips red. I am covering it like the box shows, red, white ,and blue. I been using Ultracoat on the entire plane so far but found that I have no idea where I put my red at. I do have some red but it is Topflight red. I know the directions indicate to use only Ultracoat for the durability. But I am dying to get it in the air and thinking of using regular covering for wing tips (top only)
Just looking for an opinion if I should go ahead and cover it and test fly it for time being. So I can fly tomorrow then later remove it and use the Ultracoat on Monday when hobby shop open. My concern is will the regular TopFlight covering hold up? I am just a bit paranoid about it coming off in air at WOT. What y'all think? :confused: |
i've done all mine in Solarfilm. i've taped all the edges, but the bottom middle section blew off after the edge lifted by the engine. i since recovered in Solartex in the middle bottom only to avoid this.
the type of film they use does give a nice sound tho ;) its all about getting small holes. if you see any hole tape it up before you fly, i have about 6-8 holes on top now. mostly getting it in and out of the house. |
