Whiplash Ready For Launch
1 Attachment(s)
All up weight 4 lbs 7 oz. empty tank.
Throws in degrees: 1. Low rate for flying, 8 ail, 10 ele with 30% expo. 2. Mid rate for takeoff, 16 ail, 18 ele with 40% expo. 3. High rate for landing, 34 ail, 36 ele with 50% expo.. CG as per instructions. It does move and land smooth.. |
Syd,
Hope you don't mind a few more questions as I'm working on my Whiplash. 1) Are you happy with the control throws/deflections and the expo that you previously posted? 2) How far from the inboard edge of the elevon are your horns mounted? 3) What was your method of measuring/setting the engine thrust, (2 degrees right)? In other words, how did you come up with a reference line or point? 4) Have you tried another prop? Perhaps the 8.8 x 9.75? Thanks again for all your help. I've sanded and spot filled and really worked a long time today getting ready for primer. |
email
hey s3hd i tried to email you but it bounces.
I've sent you a private message via RCUniverse.com
Whiplash Specs
S3HD:
The control throws I listed are working great. You need at least 30 degrees up elevator for good landings. Ric mounted my small Robart horns 3/4 inches from the edge with a slight angle towards the servos. To set the engine thrust, stand the Whiplash on its trailing edge and mount a disk on the front of the engine where the prop should be. I use a Sears angle finder to get my 2 or 3 degrees right thrust then I drill the engine mounting holes. Don't carve any more from the engine mount than you need and make a nice snug fit. With a Jett 50 you will have to carve out some of the mount just to get it in there. Just got my APC 8.8-9.75 props today and will be doing radar runs this week. Don't forget to use a sand paper washer on the prop driver of the Jett 50. Syd |
