RE: Kingcat-Like Design and Build
Mods, I watch for any new posts on this thread on a daily basis. Waiting in great anticipation for your release of this fabulous piece of artistry. I signed up for your pre-order list prior to your website creation. Should I sign up again there to keep my place or were you able to transfer that at the time of your website coming online? Thanks in advance, Rick
I too requested to be on the list long before the website was up and I am hoping that I am still on it as I am guessing that the list is growing quite long by now.
Thanks guys for checking in. Here is the Modkat pre-order list as of 18 April 07:
1. Rlpagemd 2. Jinzo 3. Timandchoc757 4. Sparhawk 5. Turbinecrazy 6. Arck 7. TBWood 8. Ayrtonsenna 9. Lomcevak Duck 10. Bob27 11. C. Mosa 12. J. Widner 13. macdonald77 If I missed anyone or if others would like to be added, please let me know. Mods |
Thanks Mods. Makes me feel better knowing that I'm still there. It says something for your design that so many people want to pre order a plane that has never been flown and still in the prototype phase. I imagine a lot more of us are going to want one when they see the finished product and get the first flight reports.
I'm going to be very proud to represented MRM, possibly having the first Madcat in NEW ZEALAND!
Always watching kelvin...... Wishing you and your family all the best. Ants |
Fuse Plug #2-10
Got the bottom of the fairings done using the same technique as before (figures 1-6). http://i60.photobucket.com/albums/h3...Modkat/195.jpghttp://i60.photobucket.com/albums/h3...Modkat/194.jpg Figures 1 & 2 http://i60.photobucket.com/albums/h3...Modkat/196.jpghttp://i60.photobucket.com/albums/h3...Modkat/197.jpg Figures 3 & 4 http://i60.photobucket.com/albums/h3...Modkat/198.jpghttp://i60.photobucket.com/albums/h3...Modkat/199.jpg Figures 5 & 6 The constant sanding and shaping has made them very thin is some places. This is bad because the plug will require a little coaxing out of the mold. The thin portions would surely break off in the process. To prevent this, the fairing will be fiberglassed (this weekend) with heavy weight cloth on the top and bottom. More to come, Mods |
1 Attachment(s)
Hey Mod, your job is amazing but, I was wondering if that radio continuous working,,,he he,,,
ORIGINAL: arck Hey Mod, your job is amazing but, I was wondering if that radio continuous working,,,he he,,, |
Fuse Plug #2-11
Summary Today, I glassed the fairings and applied the first coat of epoxy primer on the plug. Now, the fairings are very rigid. I can't bend or break them no matter how hard I try :D. Next, I have to wet sand the plug smooth, separate the hatch from the fuse, and one last coat of primer. Then, several coats of black enamel followed by MOLDS!!!!!!!!!! Construction First, the fairings area was outlined with painters tape (Figure 1). Then, I applied one layer of heavy weight fiberglass to the top and bottom of the wing saddle area (Figures 2 & 3). Followed by feathering the fiberglass to a fine edge (Figure 4). This was NOT fun. Even with 60 grit sandpaper it took 2 hours [:@][&:]. http://i60.photobucket.com/albums/h3...Modkat/200.jpghttp://i60.photobucket.com/albums/h3...Modkat/201.jpg Figures 1 & 2 http://i60.photobucket.com/albums/h3...Modkat/205.jpghttp://i60.photobucket.com/albums/h3...Modkat/202.jpg Figures 3 & 4 One last shape check with the grey Krylon primer (Figure 5). Here's the plug with a few thick coats of white epoxy primer (Figures 6-8). http://i60.photobucket.com/albums/h3...Modkat/206.jpghttp://i60.photobucket.com/albums/h3...Modkat/208.jpg Figures 5 & 6 http://i60.photobucket.com/albums/h3...Modkat/207.jpghttp://i60.photobucket.com/albums/h3...Modkat/209.jpg Figures 7 & 8 More to come, Mods |
Beautiful work mods.
Sweet Kelvin. I am half thinking of getting a Wren 44 to put on thtail of this little beasty!!
Spar |
ORIGINAL: Sparhawk Sweet Kelvin. I am half thinking of getting a Wren 44 to put on thtail of this little beasty!! Spar Mods |
Update: I found a new job in Yuma, Arizona so MRM-RCModels will be changing location AND setting up in a much bigger facility [sm=teeth_smile.gif][sm=shades_smile.gif][sm=49_49.gif][sm=regular_smile.gif]. Regretfully, there will be only a few Modkat updates for the next 3-4 weeks. Once the new shop is up, construction will resume.
Mods |
Congrats on the new job and good luck with the move !
(wish I had taken the Yuma job 12 years ago.... hindsight...) |
Good luck with your new job. We'll all be patiently awaiting your progress.
Just finished leafing through the pictures... [sm=spinnyeyes.gif]
Obviously very very impressive work! As a SW user myself I can really appreciate the cad work you did here. Like I said, impressive :D. I do have one quip.... As I see it the prop is awfully close to the TE of the wing. It looks to me like it would hurt performance some and make a hell of a racket while flying. Shame though that the only way to cure that would be cutting a hole in the trailing edge... [:'(] I truly hope that this isn't the case but have you tried to test this setup? Try to find a solution? Or maybe it really doesn't matter all that much since the Jett isn't so quiet itself. [sm=50_50.gif] Just my -$0.02 |
erazz, you mean it is possible to dramatically improve the noise made by using a thinner notch in the wing of the Force one ?
http://image.rcuniverse.com/forum/up...60/Ca81588.jpg |
This thing is looking great, I'm very impressed, I only wish it was bigger, like bobcat sized. I'd be all over one for turbine use if it was bigger. But I'm very impressed, great job, I can't wait to see the first one pulled from the molds!
ORIGINAL: Strykaas erazz, you mean it is possible to dramatically improve the noise made by using a thinner notch in the wing of the Force one ? I'm trying to say that I feel that there will be a lot of noise and that IMHO the only way to reduce that noise would be to move the TE away from the prop. Tell the truth I really don't now what will happen. Hopefully I'm just plain wrong! But I've learned that the different air pressures experienced by the prop when it sits close to the TE causes noise (and not the good kind of noise). |
OK erazz...
ORIGINAL: LGM Graphix This thing is looking great, I'm very impressed, I only wish it was bigger, like bobcat sized. I'd be all over one for turbine use if it was bigger. But I'm very impressed, great job, I can't wait to see the first one pulled from the molds! That's right, a CNC machine. This will drastically reduce plug manufacturing time and costs. The rig will also be available for to modelers for custom CNC machining. The customer will provide the CAD models and pricing will be based on cut time. Been wanting to do this for years, but never had the space.....till now. Just finished leafing through the pictures... Obviously very very impressive work! As a SW user myself I can really appreciate the cad work you did here. Like I said, impressive . I do have one quip.... As I see it the prop is awfully close to the TE of the wing. It looks to me like it would hurt performance some and make a hell of a racket while flying. Shame though that the only way to cure that would be cutting a hole in the trailing edge... I truly hope that this isn't the case but have you tried to test this setup? Try to find a solution? Or maybe it really doesn't matter all that much since the Jett isn't so quiet itself. Just my -$0.02 Mods |
That's right, a CNC machine |
ORIGINAL: Strykaas That's right, a CNC machine |
Mods,
The following forum section should fit nicely : "All Forums >> RC Airplanes >> Projects that I had better put aside if I want to finish the started ones, especially the Ak models Su-27" [&:] Hehe just kidding :D, seriously I would have started there : "All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD". It seems to fit prefectly ! |
heard of CNCZONE? that's all that site is dedicated to...well almost all.
