Cermark Tigershark ????
Picked up a Tigershark .60-.90 size ARF on a swap-meet this weekend. It came with a MVVS .61 engine and tuned pipe. This is a brand new ARF in the box, and so is the engine.
What should I consider when putting this plane together, and maiden it ? I think I have read something about the elevator servo setup modifications ? If somebody knows anything about this plane, please let me know. If you did any mods to it, I would appreciate some more info and pictures if possible (specially about the elevator servo setup). Any tips and recommendations will be appreciated. Thanks |
Jett .90 is in Mine. There were two versions of this plane. The newr version had a back end modification . Ask "Airgar or Flyboy"
f-20
have a 61 heli engine in mine and it does about 100MPH. now im switching to a 91 so if you can get a 91. its a great plane :D
reinaldo |
1 Attachment(s)
Here's a pic of the mod I made on the elevator.
Gary Cyclic, I wasn't aware of the different versions. As far as I knew, thew were all the same. Where did you hear this? |
1 Attachment(s)
Another
1 Attachment(s)
Have to show you what's up front! :D
If you look at the first pic, you can see the ply plate I added to the bottom of the stab. I also added one to the top that was cut to allow it to sit recessed in the fuse tail. The "high torque" servo sits upright, and protrudes through the bottom. I simply built a small shroud to cover it. The back "flourescent orange" you see is just a separate piece (to cover the opening) I covered brightly to use as billboard for my buddy "FlyBoy Dave". I won't tell you what it says! ;) :D
Gary |
1 Attachment(s)
Hole cut in horiz. stab, thin ply reinforcement, servo
rails bolted on, servo screwed to rails. Ain't pretty....but the servo won't come loose.... :D |
Originally posted by AirGar Here's a pic of the mod I made on the elevator. Gary Cyclic, I wasn't aware of the different versions. As far as I knew, thew were all the same. Where did you hear this? There were. My back end is apparently different for earlier versions. I even had a set of modified directions. |
