Prop For .15 MVVS
What prop would you run on a .15 MVVS with a short pipe for speed
On my combat planes we run 7X3 and get 17000 rpm from an LA15 but thats set up more for pull then speed. I am thinking about building a plane for the little engine, dont know what yet. Thank you |
RE: Prop For .15 MVVS
ORIGINAL: haikt What prop would you run on a .15 MVVS with a short pipe for speed On my combat planes we run 7X3 and get 17000 rpm from an LA15 but thats set up more for pull then speed. I am thinking about building a plane for the little engine, dont know what yet. Thank you 6.5x5.0 6.5x5.5 6.5x6.0 6.5x6.5 http://www.apcprop.com/cgi-bin/store...c=6a&product=+ and these sure look to me like they are in the right range. I don;t know the rpm range the engine/pipe is timed for, but these can always be clipped a bit to bring rpm up if needed. Supercool props has a few composite props listed that look in the ballpark too: GY01 Goodyear 6.8 x 4.2 C/F 15 Goodyear GY02 6.5 x 5 C/F 15 GY03 6.5 x 5.5 C/F 15 6.1 x 5.5 (F2C hub) C/F 15 21 Speed and B T/R 6.6 x 6.5 2-blade C/F 15 21 Speed and B T/R 6.6 x 7 2-blade C/F 15 MJD |
