Delta Dolly
1 Attachment(s)
Ever wanted an inexpensive uncomplicated dolly system for your deltas?
SOLVED |
RE: Delta Dolly
...a high speed dump truck....of course !!! :)
Vic, you should have thought of that. [sm=red_smile.gif] |
RE: Delta Dolly
Funny thing is it would probably work!
RE: Delta Dolly
It needs some raised letter tires and a checked racing stripe.
That or a revver's logo on the door. :D |
RE: Delta Dolly
Funnier yet is I bought and rigged it specifically to be my Delta Dolly! I am gonna try it...Looks like fun anyhow.
I have my Augered Rossi-60 and APC 10x10 on this Phenom so I do not think a hand launch would suffice. :) |
RE: Delta Dolly
Y not build one you can land on too?[sm=bananahead.gif]
RE: Delta Dolly
1 Attachment(s)
ORIGINAL: Razor-RCU Ever wanted an inexpensive uncomplicated dolly system for your deltas? SOLVED RE-SOLVED Giant Aeromaster with Walker 3.2... [)] Remove the wings, set your plane on the cabanes and go for launch. Dolly can be taxied back to the pits under it own power! :D |
RE: Delta Dolly
LOL "muy bueno" :D
RE: Delta Dolly
just dont outrun that aeromaster with the shrike:D a tripm thru that prop mught leave a mark[:-]
RE: Delta Dolly
1 Attachment(s)
Nice Crazy! You Crazy! LOL :D
I will try the plastic dump-truck next time there is no-one at the field....Or maybe at the next Revver's thing- Here is the Dolly I made based on Cobratraxxas delta dolly design. (Mine is probably not as nice but I had 1/2 of the stuff....) |
RE: Delta Dolly
Is that a tuned dent in the tuned pipe?[X(]
RE: Delta Dolly
It sure is! That is where I measure my pipe stuff. Not to the widest part of the pipe but to the DENT in the pipe- :D
RE: Delta Dolly
tuned dent made the change from f flat to B-Sharp
RE: Delta Dolly
razor... so did u try out the dolly
how did it go??? |
RE: Delta Dolly
Hey FASTCRASHER, actually I have not....I am hoping to get out for a couple hours this weekend... I tested it in the drive-way but it is like a bad shopping cart, it turns right pretty hard- :) I need to make some bends I think before a take-off roll.
I have always wanted to get something reliable since one person hand launches are a challenge even for trimmed out aircraft. CObratraxxas had good luck with his so I thought I would throw one together. I will keep you posted! James |
RE: Delta Dolly
:) point it 90 deg. left to the wind and let her go!!!!...lol:D
RE: Delta Dolly
Will do ;)
RE: Delta Dolly
[sm=75_75.gif] IM STILL WATING ... BUT I GOT TIME IM GETING A SCREAMIN DEAMON IN THE MAIL AND IF URS WORKS IM GOING TO MAKE ONE!! ...B MY TEST DUMMY RAZOR:D LOL
RE: Delta Dolly
LOL- I got pretty sick this past week so nothing...
I know the system works because Cobratraxxas has one that he has used a bit. I modeled mine loosely after his. If you have an extra $70, get the UT for the K&B-48 ;) |
RE: Delta Dolly
ORIGINAL: Crazy4Flight tuned dent made the change from f flat to B-Sharp |
RE: Delta Dolly
ORIGINAL: Razor-RCU LOL- I got pretty sick this past week so nothing... I know the system works because Cobratraxxas has one that he has used a bit. I modeled mine loosely after his. If you have an extra $70, get the UT for the K&B-48 ;) WHATS A UT??[sm=confused.gif] |
RE: Delta Dolly
1 Attachment(s)
Ultra Thrust pipe....
Dolly for my Twin Outlaw... it has to be steerable.... |
RE: Delta Dolly
Sweet!
Why does it have to be steerable? I do not see a servo or anything, does the front wheel assembly just caster? |
RE: Delta Dolly
Why steerable? do these things ever go straight? Engine torque? The tail fits in the slot ant the rudder goes in the tail wheel bracket... Works very well.
RE: Delta Dolly
ORIGINAL: evan-RCU Why steerable? do these things ever go straight? Engine torque? The tail fits in the slot ant the rudder goes in the tail wheel bracket... Works very well. the screamin deamon doesnt have a steerable rudder and if i make it steerable the rudder still doesnt extend down like the outlaw[:@] but ill come up with somthing!!;) |
