Q 500 CG.
Hi, You guys that have the Q500 low wing, what is the best CG for this plane.
Thanks Gio. |
RE: Q 500 CG.
Start at 2 5/8" from leading edge and you should be safe. Depending on how you like your racers to fly, it could vary from 2 1/2" to 3".
RE: Q 500 CG.
yep... 2.5" is a good starting point.
RE: Q 500 CG.
Some of the older airfoils liked the forward CG (closer to 2 1/2") most of the current airfoils seem fastest with a rearward CG (3")
