Help wanted
Hello,
For my next project I want to build a V-max, it has the following specs: wingspan: 1000mm Lenght: 1030mm Area: 18,4dm2 Weight: 1300gr. Profile: Ritz 1-30-10 It is original designed for a 3.5cc engine, and has been proved to fly >350km/h What I want to do is put a 6.5cc (.40 for you Americans :p) MVVS engine on it with rear exaust (RPM apx. 20.000 - 23.000) Because of the bigger engine I want to enlarge the plane with 10 or 20 % With the 20% increase the wing will have the following specs: Wingroot thickness: 3.00cm Wingroot Lenght: 30.2cm Wingtip thinckness: 1.6cm Wingtip Lenght: 16cm Wingspan: 1200cm :confused: Now my question to you guys is: Is this an reasonable thing to do, or would the thicker profile mean more speedloss that what the increase of the engine would give? What wingsises/thickness do you use on the speed models. PS: I'll see if I can scan an image of the plane and I'll post it here. |
Help wanted
That sounds good to me. If you want to double your speed, it takes 4 times the power. So using that logic, if you double your engine power, you should be able to add 20% to the size with no problems at all. I would not change the thickness of the wing, but thats just me.
by the way, did you want to type 120 cm as the length of the wing? 1200 cm is awful long for a .40 or 6 cc engine! Or perhaps 1200 mm? |
Help wanted
Oeps, 1200mm that is..... :spinnyeye
1200 cm hmm, we could be soaring with that kind a wing :D |
Help wanted
1 Attachment(s)
Here's one pic I scanned .......
I'll try to post a color picture later. |
Help wanted
1 Attachment(s)
Pic added :D
Help wanted
1 Attachment(s)
And another one...
You guys have any idea how fat this one will go? 20% enlarged with an .40 engine with rear exhaust that is. (The one in the picture does 337km/h with an .20 engine) |
Help wanted
Now that should go seriously fast with an MVVS FAI GRRT engine. Or even better: MB 40 :cool:
The wing thickness(3 cm) looks a bit thick though. The F3D airfoils have a minimum thickness of 22 mm for example. Paul |
What on earth is an MB-40?
I just traded a MVVS GRRT RE which would be a nice fit! What is it 1 MPH is .6 K? |
Help wanted
I thought 1 mile is apx. 1.6km, this results in 1km = 0.63mile
Help wanted
Here's a pic of the MB 40. Currently the most populair F3D engine.
http://home.planet.nl/~raven274/pylo...pics/f3d_4.jpg Paul |
Help wanted
1 Attachment(s)
This is the engine I plan to use:
MVVS 6,5 GFS/R - ABC - RC Quickie 500 #3068 1,20 kW@ 23000 rpm 372 gr This engine can be configures as a rear-exhaust :D An this for the nice price of 72 Euro's "quote from website:" Just AWFULL At last there seems to be an engine which seems to offer Sport 40 an alternative to the dominant Super Tigre Quickie 500 motor. The MVVS is tested for pulling a 9x7 prop. If it turns less than 17.400 rpm, it is discarded. Most will run right up to 17.700 rpm. The favoured prop for the Tigre is the 9.25x6). Together with Dub Jett's Sport Q500, this is the engine to beat! "end quote" |
Help wanted
Great design! Do you happen to have a shot from the front, especially to see the profile. Doesn't look like much pressure drag there to me!
Blue Skyy |
Help wanted
No, sorry. Got no front pic exept the drawing I posted earlier.
The Design is described in an german magazine "FMT" (FLug und Model Technik) the issue was may 1994. The plan was also delivered with that issue, and can still be ordered. building plan nr: MT1090 Name: Vmax You can order it at VTH in Germany. The adress I have is: Verlag fur Technik und Handwerk GmbH 76526 Baden-Baden Germany I don't know their home page (If they have one) |
Help wanted
Found it: www.vth.de
The plan can be found here: http://www.vth.de/shop/shopfiles/pro...&PS=1&PID=1160 The original plan only costs 9 Euro's |
