YT Mach Racer
RE: YT Mach Racer
Wow!!, that thing is really hauling!
I've got a Mach Racer with a Magnum .46 on it that is much slower than the one in the vid (about 120mph with a 9x8 APC). At those speeds, the elevons are trying to rip apart where the control horn is attached. I can't imagine it lasting long with the West .50 on it. |
RE: YT Mach Racer
Yer that started to happen with me, so I pulled the elevon off and added an extra hinge plus supports for horn. Digi servos too. swinging a 9x7. 10x6 was good too.
RE: YT Mach Racer
I'm running a TT 46 Pro/ ultra thrust in mine and it moves along smartly.I will have to dopler it some day.
RE: YT Mach Racer
Wow! I have only flown 1 (Flyboy Dave's) and even with a normal powerplant it sounded like a snare drum!
Impressive video- now put that engine in a Whip, Phenom, or DD. :D |
RE: YT Mach Racer
Losing that landing gear realy can add some speed too.
RE: YT Mach Racer
How much lighter is the diamond dust,if any, than the mach racer???
RE: YT Mach Racer
ORIGINAL: mk1spitfire How much lighter is the diamond dust,if any, than the mach racer??? Wingspan: ……………….... 34.5 in (876.3mm) Length: .………………....... 29.0 in (736.60mm) Wing Area: ……….…….... 575 sq in (37.09 sq dm) Weight: …………………..... 2.25 – 3.0lbs (1020g–1360g) Engine size: …………...... .25 - .40 2 cycle Radio: ………………........ 4-channel w/3 servos |
RE: YT Mach Racer
ahh cool thanks, I take it thats the clipped wing version?
RE: YT Mach Racer
ORIGINAL: mk1spitfire ahh cool thanks, I take it thats the clipped wing version? http://stores.homestead.com/Tetracam...iamond+Dust+RC "The Diamond Dust CW KIT features lightweight balsa, composite tubes, and light-ply construction. This lightly loaded delta wing design makes it ideal for extremely aggressive maneuvers as well as excellent low speed maneuverability. The CW version has a more narrow wingspan combined with a more aggressively swepped leading edge. Wing Span 29 7/8.in Wing Area 480 sq in Wing Loading 12 oz / sq ft Weight 2.5 -3.0 lbs Engine Req. .25 - .50 2 cycle Price $79.95 " |
RE: YT Mach Racer
Ok, so for all out speed the clipped wing is the best? The visability might be harder no?
I need to try one of these. The mach racer is pretty light. I don't know if the dd has a better laminar aerofoil for greater speed? |
RE: YT Mach Racer
It advises bigger 50 size engine for clipped wing too i notice.
I wonder if bigger dd can take a 50 as it says to 40 and what noticiable difference there is between a normal dd and clipped dd with a 50? |
RE: YT Mach Racer
ORIGINAL: mk1spitfire Ok, so for all out speed the clipped wing is the best? The visability might be harder no? I need to try one of these. The mach racer is pretty light. I don't know if the dd has a better laminar aerofoil for greater speed? Clipped wing, regular wing - if it makes a difference that matters, some would say you shouldn't fly either! :) You can put a .50 on either.. they'll take any .40-size engine (sometimes jokingly reffered to as a "small block" around here) and several are flying on Jett 60LX's, which are "small block" engines. The next size up (roughly) is a .60/.61 size crankcase or "big block". OS .46/OS .61 are two good reference points as all the clones that made these sizes standard spawned from there. There are exceptions in the non-clone war engine brands of course. You'll find some flight descriptions around here if you search the DD. MJD |
RE: YT Mach Racer
1 Attachment(s)
pic of the beast
