RCU Forums
-   Extreme Speed Prop Planes (https://www.rcuniverse.com/forum/extreme-speed-prop-planes-104/)
-   -   Looking for a new plane (https://www.rcuniverse.com/forum/extreme-speed-prop-planes-104/8715827-looking-new-plane.html)
spencer321 04-26-2009 01:27 AM
Hey i was wanting to get a speed plane i have all other planes that u can imagine but no speed plane. i have a .46 2 stroke and 4 standard servos and everything else. so please can u help me out with an extreme speed prop plane.
-Spenc
MJD 04-26-2009 11:00 AM
RE: Looking for a new plane
ORIGINAL: spencer321
-Spenc
For fast thrills on a .46 two excellent choices are a lightweight delta like a Screamin Demon or Diamond Dust, or an ARF Quickie 500 like a Viper or Predator and there are a couple more quickie model options people have unearthed around here too. What .46 do you own?
MJD
spencer321 04-26-2009 03:59 PM
magnum runs great tho
tIANci 04-26-2009 10:55 PM
I love the GP Viper because its fast enough to thrill but also easy enuff to handle like a trainer.
freakingfast 04-26-2009 11:04 PM
The Viper, but read up on the mod/build threads to keep it together.
spencer321 04-27-2009 10:09 PM
where would i find those threads?
tIANci 04-27-2009 10:53 PM
The new ones are ok IF you are using a stock motor, on the TT46 I had no issues but when I used the Rossi 53 and the Jett Q500 the firewall started to detach. The plane is not made for hot motors. If you need info on mods try here: [link=http://www.rcuniverse.com/forum/m_7651229/tm.htm]Viper 500 mods[/link]. Read carefully ... esp on the Vtail, you need to shim it properly by flying her. :)
Crazy4Flight 04-28-2009 07:58 AM
I bought a Viper used it flew fine. firewall failed with ST.51 and it was glassed internally but not by myself
tIANci 04-28-2009 10:14 AM
The new batch of Vipers are glassed inside and outside, you can feel it under the covering but it comes off easily. Best to remove the tri-stock and glass on the inside and redo it. Also to pin the firewall would also help. I need to now re glass mine. Aarrggghh ... a messy job.
