engine swap???
I have a modeltech funfighter P-51. I'm running an OS .46 LA with a MAS 9X8 prop. on the bench tuned for flight it's taching 14200 RPM. do you think if I swapped out the LA for a .46 AX and put an 9x10 prop on it, I would get a noticeable gain in the top speed or the added weight would defeat the purpose of the swap? right now the plane is an estimated mid 80's in level flight. I'd like it to be faster!!!:D
RE: engine swap???
I would, I think you will notice quite a difference.
RE: engine swap???
i'm putting a NELSON 40 on mine
RE: engine swap???
Put in a GMS 47 and a 9x7 prop. Around 15K rpm
RE: engine swap???
i would say 8.8x9.0 @ 19000 +
RE: engine swap???
ORIGINAL: RANIERY i would say 8.8x9.0 @ 19000 + I know, old thread. I've been out of action for 7 months, catching up on old subscriptions (all in this forum). |
RE: engine swap???
i meant those rpm with a nelson
RE: engine swap???
The Nelson will test to see how well the Fun Fighter is put together.
RE: engine swap???
use a 10x7 APC prop with the OS AX, you should be somwhere around 105 mph.
I don't think the 9x8 will be any faster. |
RE: engine swap???
it might turn a 9x9....but not a 9x10 at that RPM
but you really need is a Nelson or a JETT. |
