O.S. 46 max vx
Hello fellow speed freaks,
I got an os 46maxvx engine and i am looking to get a fast plane out of this engine. Does anyone have any ideas about what plane and what prop size i should use? I don't want a flying wing such as the diamond dust or whiplash. But i honestly can't figure out a good plane to stick this thing into the only speed i see myself acheiving is about 110mph. If im lucky. But if anyone has some good advise please respond. Thank you in advanced |
RE: O.S. 46 max vx
phoenix strega or one of don stegalls Q40 racers, they run about 150 on a TT40 pro, go to the pylon forum and do some reading, sahartman has done some build threads on these
RE: O.S. 46 max vx
I have a full composite lyle larson dego red that still needs built, Its just not a fun or easy task. That probably is my only option for this engine. Thanks for the fast reply.
RE: O.S. 46 max vx
ORIGINAL: mustang258 Hello fellow speed freaks, I got an os 46maxvx engine and i am looking to get a fast plane out of this engine. Does anyone have any ideas about what plane and what prop size i should use? I don't want a flying wing such as the diamond dust or whiplash. But i honestly can't figure out a good plane to stick this thing into the only speed i see myself acheiving is about 110mph. If im lucky. But if anyone has some good advise please respond. Thank you in advanced MJD |
RE: O.S. 46 max vx
Did you snag that scratch and dent one? Nice discount for a missing manual. I thought the prop shaft was too short for a prop?
RE: O.S. 46 max vx
Tru turn makes an adaptor for this engine. They sent me one adaptor TT-0140-A. Its a really nice adaptor but it only grabs about 2 threads So i got the short shaft adaptor ordered should be here in a couple of days TT-0141-A. For anyone that is unsure like myself about what spinner nuts to use make sure you check out Tru-Turn web site its helpful and if your engine isn't listed just give them a call. Im gonna have to look into the matney zoomer. Thanks MJD
RE: O.S. 46 max vx
I would have suggested one of my deltas but you nixed that in the first message... :D
MJD |
RE: O.S. 46 max vx
If you have a Lyle Dago, just use that, its basically built.
RE: O.S. 46 max vx
Im checking into the Matney Zoomer that sounds like a good set up. As far as the dego red i would like to put a nelson engine in that. And i need to find a good painter lol.
RE: O.S. 46 max vx
The Matney plane will be more work than the Dago.
RE: O.S. 46 max vx
The Matney Zoomer looks cool,I like the looks of it, a Jett 60LX would be slammin'.:D
