Diamond Dust Electric
A while back I aquired a Diamond Dust from a friend of mine (Mike Connor). I first mounted my Rossi Q40 engine on it, but then decided to try an electric on it for a change. I'm going to do some surgery on it with a battery tray and hatch/fairing. I have 3 power systems to choose from, so I weighed the plane with each system.
(1) Medusa 28-56-2800 , Castle ICE 100 amp esc , 3S2P 4400 mah 30C pack : 2lb. 13oz. spins a 6X5.5 prop 31000 at 1000 watts (currently goes around 130 in my 3lb. 7oz. ritewing) (2) Medusa 36-50-1600 , Castle HV-85 amp esc , 5S1P 2250 mah 30C pack : 2lb. 11oz. or 5S1P 3300 mah 20C pack : 2lb. 15.5oz. ,calcs show 6.5X6.5 prop 26000 at 1000 watts , pitch speed 160 and 90-100 oz. thrust. (3) NEU 1907-1.5Y (915) , Castle HV-85 amp esc , 8S1P 2650 mah 30c pack : 3lb. 6oz. ,calcs show 7X8 prop 23900 at 1240 watts , pitch speed 180 and 120+ oz. thrust. Has anybody ever flown a Dust at 3lb. 6oz. ??? What do you guys think I should go with? Hopefuly Mike will chime in too. I'd like to go with 2 or 3 , so I can leave my Ritewing intact. Scott |
RE: Diamond Dust Electric
You better go with #3 to be sure you have enough power to fly upwind.
ORIGINAL: Scott J ... (2) Medusa 36-50-1600 , Castle HV-85 amp esc , 5S1P 2250 mah 30C pack : 2lb. 11oz. or 5S1P 3300 mah 20C pack : 2lb. 15.5oz. ,calcs show 6.5X6.5 prop 26000 at 1000 watts , pitch speed 160 and 90-100 oz. thrust... ...Has anybody ever flown a Dust at 3lb. 6oz. ??? What do you guys think I should go with? Hopefuly Mike will chime in too. I'd like to go with 2 or 3 , so I can leave my Ritewing intact. Scott Your electric specs probably wont mean much to many in this forum but we will see. My vote is #2 because since #1 is in a RTF wing and should be left there IMO and #3 doesn't have enough extra power for the weight added. At 575 sq in the dust will fly ok at 3lb 6oz but will shine at under 3 lbs. My first Dust probably weighed around 3.5 lbs after 100 flights and many repairs and it flew fine. There are a few Screamin Demons flying well at 3+ lbs and have almost 100 sq in less wing then a Dust. There are also a few 4+ lb big block Demons getting ready to fly. |
