Go Back  RCU Forums > RC Helicopters > Flybarless Helicopters
Reload this Page >
Cant control and crashed
Flybarless Helicopters Discuss flybarless rotor head systems for all helicopters right here.
Old 07-14-2011, 10:22 PM
saintsokwitit
Default Cant control and crashed
Trying to just get my Walkera 450D01 off the ground with NO luck.While spooling up this time with the heli facing away from me it keeps turning to the left and I cant control it. How come the flybarless gyro is not stopping it from spinning?
Old 07-14-2011, 11:09 PM
mormathi
Default RE: Cant control and crashed
Either your gyro is compensating in the wrong direction, og you have a reversed rudder.
-Put your helicopter on a table with radio and receiver/gyro on ( disconnect motor to prevent it from spooling up) Move the tail sideways. When you pull the tail the gyro should compensate in the opposite direction and the slider should move away from you.
If the slider moves against you the gyro is compensating in the wrong direction and should be reversed.
-Move the rudder right. Look at the tail. Your blades shold have a positive pitch to the left side ( tailrotor moving tail to the left to yaw front to the right)
If this is not the case you have to revers your rudder.
Happy flyiing.
