Flybarless Helicopters Discuss flybarless rotor head systems for all helicopters right here.
FIX FOR TREX600N ONE WAY BEARING!!
Reply
Old 09-24-2011, 08:49 AM
Callouscade
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default FIX FOR TREX600N ONE WAY BEARING!!
After the 3rd flight, my one way bearing siezed. wouldn't spin. replaced it. then it was the same tightness as before, but when i first built it, i never thought to check if it spun with the blades. i just moved it and made sure that the one way was functional. And i found the problem that makes it sieze and be tight when installed!
After quite the expirimenting i found that the one way bearing shaft actually slightly compresses. as the bolt tightens, it squeezes it ever so slightly. this makes it stiff in one spot on the bearing. once i loosened the screw, works GREAT!! but i can't fly with a loose screw. so to make sure that the screw is secured, i flipped around the lock nut, so that the bolt threads first into the nylon lock to secure it. this way the bolt won't come out because it's in the locking part and it also it JUST touching the other side of the hole. the bolt has not movement but is loose so that the bearing works great!!
ANother fix is to do that but get a longer bolt.
hope that helps someone!
Callouscade is offline
Reply
Display Modes
