EDF Delta Wing Help
ON, CANADA
EDF Delta Wing Help
Hi,
I am interested in a delta wing configured aircraft for my start into EDF. I do not want anything fancy or scale, I want something that looks like the balsa usa enforcer or force one. if possible. I have my heart set on a foam EDF in that style, I may build one if there isnt something similar on the market. Has anyone got any idea of where to find one, or should I just scratch build?
Thanks in advance.
Thanks in advance.
My Feedback: (89)
RE: EDF Delta Wing Help
Hello Urbanking,
Here's my throw together Double Delta made from Fan-Fold 1/4 inch insulation board.
Used F-16 EDF for Power, four (4) 9g Servos, Zagi type compartment for receiver, 1300 mAh 3S Li-Po battery, & ESC. Balance at motor Fan.
Front Delta including Elevator 18" wide 12" cord 45 degrees, elevators ~1-1/2"
Main Delta including Elevator and Ailerons, 28" wide, ~8" straight cut at tips, 22" cord, 2" wide Elevator & Ailerons. Front ELEVATOR goes DOWN, Rear ELEVATOR goes UP.
Fuselage Hight to fit the Fan unit that is used.
Have Fun,
Ken AMA 1528
Have Fun,
Ken AMA 1528
