If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 2 of 2
  1. #1
    Join Date
    Mar 2009
    Raleigh, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    nitroplanes Stuka 1400 mm
    Hello all,
    I just piled a 1400 mm Stuka from nitroplanes this weekend. I came out of a steep dive to get some scale look and then pulled out and flew normally. All of a sudden, I lost all signal and the plane bummed in the ground. Guys at the field told me I had a Spektrum brown out due to using an Orange "park flier" Rx. I've used this Rx on the plane for many flights without any problems. In fact, I fly my slowstick with the same Rx even at farther distance than the Stuka. My theory is that the steep dive does something to the ESC. Is it possible that high revolutions on the prop can somehow overload the ESC? I remember doing some steep dives before with the stock 50 amp ESC and the ESC only partially worked. Luckily, it worked enough to prevent a crash. I ended up having to get a Dynum from Hobbypartz.
    Thanks for any input,
    -Geoff
  2. #2
    Join Date
    Jan 2011
    Tacoma, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: nitroplanes Stuka 1400 mm
    I have two of these aircraft. I replaced the ESC on both, as they are known for being unreliable. I use a 60 amp OPTO ESC with a 5A UBEC for the radio. There are 8 servos in this aircraft, so the stock BEC on the ESC is working pretty hard. It is a bummer you lost this plane, as they are really great flyers. I hope you rebuild.-Metalguy
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
