Foamies! - RC Electric Foam Aircraft Discuss rc foamie electrics here (i.e. Zagi, Tazz, ProJeti, wingo)
PZ micro T28-safe glue
Reply
Old 01-24-2014, 04:03 AM
JPerrone
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default PZ micro T28-safe glue
What glue/adhesive is ok for this plane? the little plastic lever for the rudder is loose on it, I am thinking a little glue would be ok but I know that not all glues work on foam planes
New out of box; maybe a little too much wind as it didn't go where I wanted it to; and the rudder is hard over to one side now!!! Not sure why. I tried adjusting it with trim but it's too far over for that. So it looks like the only fix is to break the connection that is near the rudder; or the one inside by the servo.
Anyone have to this? I am thinking wrap with thin thread, coat with superglue and go. But maybe there's a better way that is secure
Regards
JPerrone is offline
Old 02-24-2014, 09:44 PM
torelentless
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use 5 minute epoxy but on a micro you can probably use anything
torelentless is offline
Old 02-26-2014, 06:18 AM
JPerrone
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I looked up what kind of foam the T28 is made of; I thought the source said it's Z-Foam.
I looked up Z-foam; apparently it's CA safe
I tested CA on a non critical area; and it ate it up.
So, I don't think regular CA will cut it!!!
I've ordered some Foam Safe CA; I will repeat the test and report back
Regards
JPerrone is offline
Reply
Display Modes
