Foamies! - RC Electric Foam Aircraft Discuss rc foamie electrics here (i.e. Zagi, Tazz, ProJeti, wingo)
1100mm EPO Warbirds
Old 04-14-2014, 07:47 AM
superchargedill
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 1100mm EPO Warbirds
Hi Guys,
I have been flying nitro for about 25 years now and recently picked up a couple of electrics at 2 different swap meets. The first one was a Parkzone P-47 with a battery and receiver for $50.00 ( no landing gear ) and the second was a Parkzone P-51 with a battery for $30.00. Both were in excellent shape. I really like the size, ease of transporting ( can leave the wings on ) and picked up some extra 11.1v 2200mAh 20C Venom batteries at $18.99 and once in a while I get a coupon and pick one up for $14.00.
My boy (11years old) flies the P-47 and would like to add retracts. Which retracts would work the best on this Parkzone plane ?
I am flying the P-51 and love the way it flies and handles. However I would like just a little more speed. Is there a different prop that may work ? I see that Venom has 2 other 2200mAh batteries that will fit either plane. One is a 40C and one is a 50C. The P-47 has a 30amp ESC and the P-51 has an 18amp ESC. I am trying to learn what works with what along the way. Can we use a higher C rating or will that over power our current ESC's ?
If I were to upgrade the motor and ESC on the P-51, what would be a good fit that would work with an 11.1v 2100mAh 20C or would a new combo handle the 2200mAh 40C/50C better ?
My next question is, Which company makes the best quality EPO/ Foam Warbirds in the 1100mm range 39"- 45" wing with retracts. Different companies for each plane is okay.
P-51
P-47
F4U
BF109
FW190
Zero
Thanks, Dil Brandow
superchargedill is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
