Flyzone Switch CG question for low wing config
I'm fairly new to this site and this is my first post in the forums so I hope I have posted this question in the right place. I'm not new to the hobby by any means but my story is I have been absent from the hobby for almost 6 years and in 6 years a lot has changed in the foam aircraft department. I decided to buy the Flyzone Switch RTF and have been flying it in the high wing config for a few weeks and decided to switch it over to the low wing to get more out of the model and then move on. The manual says that balancing the model is the same for both the low wing config and the high wing but even moving the battery as foward as possible it is tail heavy. I was always used to balancing mid and low wing models upside down. The manual does not go into great detail with the model in high wing and I just want to be sure I have it procedure down. It balances easy in the high wing.
