Dollar Tree foam board, remove paper skin or not
I am building an ******** prop jet and don't know if I should take the paper liner off or not. Without the paper the foam is very delicate and easily broken. Will the jet be too heavy with the paper??
The paper add both strength and weight, The problem some people have is once built the paper starts coming off anyway. In Florida the humidity would probably make it happen fast
(I would think).
It sounds like the general rule for getting the foam so much cheaper than depron is pulling the paper, and reinforcing with wood or carbon spars...
rcgroups has loads of info on this area as well.
(I would think).
