Zagi 400X Battery replacement
CA
RE: Zagi 400X Battery replacement
I just went onto that website(www.cheapbatterypacks.com) and that battery pack should work just fine in your 400x. Its very similiar to the CP 1300 battery from www.zagi.com. It will give you alot of power and a longer flight time by about 5 minutes. I'd say go with that battery. Because I flown the zagi's CP 1300 and cp 1700 mah batteries in my 400x and its a huge difference. And this 2100 mah is around the same weight as the CP 1300 and will give off even more power do it being 2100 mah. Hope this is of some help, bye.
CO
It's a fantastic battery... you can buy them on Ebay cheaper though. They're going for $25 All mike's batteries are good deals. I run them on my brushless setup. I can't tell you the difference in flight times as that really depends on throttle management but all things being equal you'd expect a 20% increase or so
