Krylon "Fusion" paint
I just seen an add for this new paint that is made for molecularly bonding with plastic. Its called Fusion and I believe Krylon makes it in about 30 colors. I am not sure if it will harm exposed foam but it probably would work on the thin plastic covering on blue cor. I can't get it where I live but thought I would suggest it here for someone to try and give their opinion on it.
RE: Krylon "Fusion" paint
I painted a Sky Scooter and the bottom of a Slow Stick wing with it. You have to spray thin coats from a distance because it absolutely WILL eat foam if it goes on too wet. Also, never try to paint over it--that guarantees foam disintegration.
It is the best for new plastic parts, like spinners, struts, propellers, etc.
