GWS C-47
NJ
GWS C-47
I just purchased the GWS C-47 I have little electric time and no foam time. Im looking to touch up the paint job on this C-47. Its olive drab and some has come off because of taping and the hinge areas are white and general clean up. I found some acrylic paint that doesn eat foam. But the color is a little off. What can I paint this thing with that wont turn it into a pile of goo?
SD
RE: GWS C-47
Virtually all water-based or alcohol-based acrylic paints are safe for foam. If you plan to airbrush, then go with alcohol-based acrylics and thin with isopropyl alcohol. But, if you're just going to brush it on, then go with water-based acrylics, and don't worry too much about the weight. There are also some spray acrylics available at craft and hobby stores that are foam safe. But, don't use a spray paint unless it says it's safe for styrofoam.
MN
RE: GWS C-47
I painted mine with brush on acrylic paint called model master acryl, it works quite well,don;t worry about weight,i put 2 coats on to cover the silver,i fly mine stock with radio shack 9.6v 1600 nimh 8 cell ,will fly 18 min on 1/2 throttle.
