If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 14 of 14
  1. #1
    Join Date
    Oct 2004
    Ankara, TURKEY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Cessna182 Flyzone
    Dear Friends,
    I have just received my new electric Cessna 182. It flies great. Anyone tried to convert it to brushless-Lipo battery combination yet?
    Any advise will highly be appreciated.
    Feyzan EREL
  2. #2
    Join Date
    Dec 2003
    Tananarive, MADAGASCAR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Cessna182 Flyzone
    yes! mine is powered by the himax 2025- 4200KV brushless motor swinging an APC 9x6" through himax 4.2:1 gearboxe. Thunder power 3cell- 2100mah is the pack I use with phoenix 25A ESC. This set up makes the skylane an agressive flyer!!!
  3. #3
    Join Date
    Jul 2006
    Wellsville, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How does she fly stock? My friend is getting one and want to know if its a good trainer or not. Would you recemend it to a complete beginer?
    Willing to work for Norvel Engines ; )
  4. #4
    Join Date
    Aug 2002
    Ankara, TURKEY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks alot Alliot, I will try. Did you make any modification for the engine and battery compartment?
    Feyzan
  5. #5
    Join Date
    Jan 2007
    Wellsville, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm looking into buying the Cessna 182 but it will be my first plane other than an AirHogs AeroAce. Is this a good trainer?
  6. #6
    Join Date
    Jul 2006
    Wellsville, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    does it have good power and what kind of flight times do you get with it stock?
  7. #7
    Join Date
    Dec 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    WASPS> The himax 2025 motor that swings the APC 9x6 " pulls 16.5 amps through 4.2:1 himax gearbox (6.2T) at full throttle. I use 11.1V 2100mah 15C lipo battery; the flight time is about 17 minutes with some throttle management. But, it's only 9 to 11 minutes if you abuse it a little bit. Anyway, if you use electric power, it is not good to use full throttle all the time because it may shorten the battery life. This set up meets my expectations from this plane. Of course, you can fly it with the stock set up, but it's too marginal. Besides that, I don't recommend this plane for a beginner because it is a scale. Tell your buddy to learn to fly with the mutliplex easy star.
    Feyzan> I attach an E-flite stick mount into the firewall and then slide the gearbox with the motor into the stick mount. You can use a glue or screw to secure it. You have to file each side of the battery compartment a little bit so that you can put any rectangular shape-3 cell lipo pack in it. Also, I've just converted my plane into a tail dragger because the two pieces of plastic that secure the nose wheel are very weak. I will try to post a picture next time.
  8. #8
    Join Date
    Jan 2007
    Frederick, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've got one flown it a few times Winter here and all. I love it flys great easy to handle and smoooth Not really a begginer plane but with a buddy box you could learn easy enough. Everything in the box and room to grow with it as well. I think it's worth the money
  9. #9
    Join Date
    Jun 2006
    Gordonesville, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Horrizon Hobby has there 182 Cessna ARF for 69.99 and they throw in a Park 400 outrunner motor {920kv} which sells for 60.00 FREE.This has to be one of the best deals around.I could not pass up this deal.Has anyone here flown the Eflite 182 ? This should be a real good combination, should have plenty of power for aerobatics.
  10. #10
    Join Date
    Dec 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have the E-flite Cessna 182. I flew mine with the Hobby Lobby 400 XT outrunner, which is almost the same as the E-flite 400 outrunner. It flies great, but it will fly better with any 400 size inrunner brushless motor, which is similar to the one I use for my Flyzone Cessna 182.
    I fly both planes with the same prop and I feel the difference in power and efficiency. Actually, the power makes the difference, but not the airplane. Both motors pull the amount amperes at full blast, but the inrunner with the gearboxe outruns the outrunner in term of thrust. A lot of folks in this forum prefere to use outrunner to inner brushless motors because there is no need for gearboxe. But, a gearboxe makes a powerplant more efficient if one knows the prop and gear ratio combination.
    My complaint about the E-flite Cessna 182 is the airframe, which is very weak compared to the Flyzone Cessna. The battery cover is also very flimsy. It seems that the fuselage is made of foam, which is not durable. It is similar to the one that farmers use for meat packing. That's why, Horizon Hobby sells this plane with the E-flite 400 outrunner for $69.99. About durability, I vote for the cessna 182 by flyzone.
  11. #11
    Pa-18cub150's Avatar
    Join Date
    Nov 2005
    ainsworth, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I just got a flyzone Cessna 182 yesterday and assembled it last night. This is my first electric plane.
    With no wind I had to brave temps in the low teens to first flight it . It seemed that it didn’t have a lot of power to spear. Both hand launches hit the ground before struggling into the air. Is there enough power to take off from the ground?
    Are there any upgrades or hop ups that are plug play? I am a little behind the learning curve and a little confused about motor size, electronic speed controls and batteries. Can the motor be up graded with out changing the electronic speed control?
    Good judgment comes from bad experience, and a lot of that comes from bad judgment.
    Cub brotherhood # 29
  12. #12
    Join Date
    Dec 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Until now, I have seen only Ready To Fly versions. If you feel that the stock motor is not strong enough and you don't want to spend more money on this plane , replace the stock 380 motor with the Graupner Speed 400 6V motor or 400 BB without changing the ESC. Besides that, replace the stock Nimh battery pack with any 2-cell lithium battery that has a capacity between 1300mah and 2200mah. You can get one them from hobby-lobby.com.
    If you are really addicted to power, you can try my set up that I've already posted in this thread in reply to Feyzan.
  13. #13
    Join Date
    Jan 2012
    Commerce, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Need some help! I have the Hobbico Flyzone Cessna 182 select scale. I broke the nose gear and now have a replacement. I think I am going to have to cut in the foam to remove the old one. How do I do it and what glue from Home Depot should I use. I am as green as they come but pretty crafty. Any help would be appreciated! Thanks!!
  14. #14
    Join Date
    Dec 2011
    Van, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Im not sure what the steps are to replace the gear on that plane but one glue Ive used on my foam spitfire MK IX is 5 min epoxi. Sets up strong and quick, does'nt effect the foam. Not the lightest glue in the world so if thats a concern then best to get the proper glue made for ZFoam. Slow CA works well too.
    Cheers
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
