Motor mount for GWS system
What's the lightest way to attach a GWS two motor (7.2V) system to a foamie? For the fuselage, I am using 3/16 foam board with the paper removed. Playing with the motor/prop while holding in my hand I have the feeling that the foam alone will not handle the touque and vibration.
Later;
D.W.
Later;
D.W.
Mount
What a lot of kits do is put a wood stick into the foam a little way.I have also used GE silicone adhesive, it a little heavy but you can get a little shock absorbation from it, that is if the plane has a enough area to make a cradle for the motor.
My Feedback: (7)
TX
D. W.
I would insert a spruce stick into the fuselage, the deeper you inset the stick, the stronger the fuselage will be and the better your bird will survive. If you wish you could laminate (one or both) the fuselage side(s) with a piece of paper/index card at the mount location.
If you have not tried it yet, give probond a try, I really like it!
