please need help what brushless motors are compatible with the stormlauncher by air hogs
please need help wehat brushless motors are required to up grade the storm launcher by air hogs.directional thrust,7.4 lipo batery.
TX
RE: please need help what brushless motors are compatible with the stormlauncher by air hogs
How much does it weigh? You could probably get away with a bp-21 brushless motor from bphobbies.com
Kevin
Kevin
kevin i belive it weighs about 2 lbs it has twin propeller one motor on each side and turns with diferential thrust.
TX
Wow ummm ok that changes things somewhat........directional thrust you say.........must have missed that part.....um..... ok before I give you bad information look in the micro electric flight fourms and find the stormlauncher thread. I am sure someone there will be able to help you better than me. As a matter of fact I have a link for you.[8D]
Sorry,
Kevin
[link=http://www.rcuniverse.com/forum/m_4433291/tm.htm]Hope this helps[/link]
Sorry,
Kevin
