Foamies! - RC Electric Foam Aircraft Discuss rc foamie electrics here (i.e. Zagi, Tazz, ProJeti, wingo)
Free EXTRA 300S from ********.com BUILD!
Old 12-13-2008, 10:20 PM
calvino
calvino's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Free EXTRA 300S from ********.com BUILD!
5-minute epoxy works good for holding carbon in, trust me, once you get stuff from hobby city.... your addicted () best of luck, hope it turns out good[8D]
calvino is offline
Old 12-20-2008, 05:51 AM
cineas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
perfect, very nice
show
http://worldtv.com/cineas_-_tv/
cineas is offline
Old 01-01-2009, 04:45 PM
mkharv3
mkharv3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have still not got my stuff from hobbycity.com. I guess it is due to the Holidays but I am not in a hurry. Anyways I have a new questions that I need help with. Please click on the link where I posted a new thread on the battery/charger forum maybe someone could help here too. Thank you very much again.
Mark
[link]http://www.rcuniverse.com/forum/m_8306431/anchors_8306431/mpage_1/key_/anchor/tm.htm#8306431[/link]
mkharv3 is offline
Old 01-07-2009, 06:38 PM
mkharv3
mkharv3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got some time to work on the extra. Here are a couple pictures for your viewing pleasure.
Mark
ID:	1105814   Click image for larger version
ID:	1105815   Click image for larger version
mkharv3 is offline
Old 01-07-2009, 06:42 PM
mkharv3
mkharv3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are some pics now of the power system. I do have questions though. First what is the best way to get the motor and the ESC connected. Also which is the best way or could you give me a link to the connections I need to add to the ESC for the motor and the battery?
I know probably a stupid question but I am again electrics stupid.
Thanks again.
Mark
ID:	1105817   Click image for larger version
ID:	1105818   Click image for larger version
ID:	1105819   Click image for larger version
mkharv3 is offline
Old 01-07-2009, 08:58 PM
  #31
mkharv3
mkharv3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
MY LIPO CHARGER HAS BEEN SHIPPED ALMOST TIME TO FLY!!!!!!!!!!!!!!!
THANKS AGAIN HOBBYCITY.COM
mkharv3 is offline
Old 01-08-2009, 11:03 AM
  #32
jstern429
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like all you need is a male dean's connector and you are all set. From your pictures the motor has the ends you need to put on the ESC (pull off the small gold thing's on the end of the motor wires and solder them to the ESC and use shrink wrap on them). The attached picture is what you will need and what it looks like when completed. If you havent soldered before practice before you do them as a poor solder joint will fry the motor & ESC and possibly the battery.
jstern429 is offline
Old 01-08-2009, 04:15 PM
  #33
calvino
calvino's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just make shure your POLARITY (red to red black to black) is right or you will fry your electronics, looking like it is comming along good, can't wait to hear how it flies[8D]
calvino is offline
Old 01-08-2009, 07:28 PM
  #34
mkharv3
mkharv3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow where was I on that one. I did not know that the gold peice came off. Well I soldered them on and now I have no clue as to which wire connects to which plug. On my ESC they are all black and the motor has red, yellow, and black.
Also I am going to go to the hobby shop tomorrow to get a deans connector.
Just go to wait for the hobby city order to get here to charge that batts.
Thanks again guys.
mkharv3 is offline
Old 01-10-2009, 01:05 AM
  #35
calvino
calvino's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
once you get your other stuff like a battery charger plug the wires in with the ESC # side facing up with the motor and prop as it should be, 99% of the time its correct, if its not, then switch the 2 OUTSIDE plugs and it should work good[8D]
calvino is offline
Old 01-10-2009, 09:35 AM
  #36
mkharv3
mkharv3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok I will try to figure out which side is up because it is not marked. Worst case is it safe to connect the middle wire of the motor to the middle ESC wire. Also if they are backwards will it hurt anything or will it just be in reverse.
Mark
mkharv3 is offline
Old 01-14-2009, 02:06 AM
  #37
calvino
calvino's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yes, middle wire allways goes to the middle wire on the ESC, other than that its prety simple, if its reversed, reverse the two outer wires, just currious how you are cutting the foam, an x-acto knife or a hotwire?
calvino is offline
Old 01-25-2009, 10:43 AM
  #38
mkharv3
mkharv3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I got around to testing the motor and ESC and everything works great. That little motor has some power. Honestly I never knew these little electrics would be this much fun.
However I am still not ready to fly this Extra due to messing around with another project.
I got a little Slow Stick to teach my son. It only cost me 20.00 brand new from Horizon Hobby. I got the motor and ESC from hobby city. It is done and I will try to get a mintue to post pictures later. So now I just need to get another micro receiver and finish the Extra up. By the way have ant of you ever tried any of those knock off ebay receiver specials?
Also what is the best linkage or ways to mount micro servos to the control surfaces. Any suggestions will be appreciated.
Thanks again. Mark
mkharv3 is offline
Old 01-25-2009, 03:45 PM
  #39
calvino
calvino's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
some us micro pushrods, some use piano wire 'joints" (aka things at horns) and carbon for the rest, i am going with micro pushrods on my super small 3D, with your power combo, im thinking maybe piano wire would do the trick [8D]
calvino is offline
Old 02-02-2009, 02:22 PM
  #40
cap10fan
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking good Mark! Any more progress on the Extra build?
cap10fan is offline
Old 03-27-2009, 04:06 PM
  #41
mkharv3
mkharv3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry for the late reply but I had a change of plans and built my son a 1/2 a trainer with the electrics but it flies like crap so I will reengage with the foamy.
Mark
mkharv3 is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
