Foamies! - RC Electric Foam Aircraft Discuss rc foamie electrics here (i.e. Zagi, Tazz, ProJeti, wingo)
elapor foam primer
Reply
Old 03-30-2009, 05:56 PM
snobelt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default elapor foam primer
have any of you found the primer (in the US) that's needed for painting elapor foam? That's the foam used by Multiplex. I find shops in the UK that carry it but none in the US. Don't mind buying from the UK but I don't like the wait time or the shipping cost.
snobelt is offline
Old 03-31-2009, 05:44 AM
rwolfe9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: elapor foam primer
I tried block filler. It is used by painters for filling in the holes in cement block before painting. I used it on my son's F-15 foamie. It took a few coats, but it did fill all the tiny holes.
rwolfe9 is offline
Old 04-02-2009, 02:17 PM
Jim W.
Jim W.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For ELAPOR foam, I found that RUST-OLEUM "PLASTIC PRIMER" actually "Bonds" to ELAPOR foam, then any other Rust- Oleum paint can be used for the color desired. The plastic primer is a semi-flat white that matches both Multiplex and Parkzones' white foam pretty close. Clearcoat can be used to make the primer look "Glossy". Note: Always use denatured alchohal and/or acetone to wipe down foam first to remove any mold rlease agent and BE SURE TO DO THIS IN A WELL VENTILATED AREA !!!!!!!
Use the low tack masking tape when using the tape on a painted surface and ALWAYS peal the tape back onto itself when removing it.
"DUPLI-COLOR" auto spray paint in the "rattle cans" also "Bonds" extremely well to ELAPOR foam without any primer. Do Not use this over the RUST-OLEUM primer or paints because it reacts with a great "Orange Peel" affect..........ask me how I know !!!!!!!!
PLEASE NOTE THAT THE ABOVE "IS NOT" FOR DEPRON OR REGULAR STYROFOAM of any kind.
GOOD LUCK and Happy Painting !!!!
Jim W. is offline
Old 04-03-2009, 07:26 PM
LouieB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: snobelt
The Multiplex primer is not actually a paint primer. What Multiplex calls a primer is actually a liquid that is used clean the surface of the elapor foam. You then can use primer paint for you first coat of surface.
I have two cans of the Multiplex primer and it works quite well. It has toulene and some other goodies in it that I can not deciper from German to English. It smells a bit like paint thinner and acetone. You can use denatured alcohol to clean the surface but you really need to sort of etch/rough the surface for a good primer coat to stick. You can try using paint thinner, but do a test on a piece of extra elapor first. Wipe a thin coat on and wipe it off just as quick.
LouieB is offline
Contact Us Archive Advertising Cookie Policy
