Parkzone Stryker 27C Questions
NC
I tried looking through all the Stryker postings, but it's like looking for a needle in a haystack.
Just two questions:
1) Is there now a direct replacement for the Stryker motor? Las time I inquired, there were no motors that would fit the present motor mount.
2) Can I use a 7 X 5 prop with the Stock motor?
Thanks in advance,
Just two questions:
Thanks in advance,
TX
RE: Parkzone Stryker 27C Questions
I seem to memember the Series Six required only a very small modification to bolt holes in the stock motor mount. There may be two Kv's for the Series Six. Pick the one that suits your needs.
NC
ORIGINAL: Bozarth
Absolutely no modification needed. I just installed one on a Stryker for our monthly race.
Kurt
Kurt
