Foamies! - RC Electric Foam Aircraft Discuss rc foamie electrics here (i.e. Zagi, Tazz, ProJeti, wingo)
Blue foam painting?
Reply
Old 07-08-2010, 06:13 PM
c130nut
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Blue foam painting?
I have a plane made out of blue sheet foam from Lowes. I am wanting to paint it but do not know which paint is safe. Any ideas? I can use a spray can or use an airbrush, but not really good at it.
c130nut is offline
Old 07-15-2010, 03:28 PM
jdetray
jdetray's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Blue foam painting?
Acrylic craft paints are foam-safe and can be thinned with water or Windex and sprayed with an airbrush. These inexpensive paints come in many colors. You will find them in small bottles in craft stores and in the craft department of stores such as Wal*Mart. You can also apply craft paints with a brush, of course.
In spray cans, Krylon Short Cuts and Krylon H2O are foam safe. Krylon Fusion spray paint may also work, but test it on scrap foam first! Other brands of spray paint can also work if you spray very light coats from fairly far away, so that the spray paint goes on almost "dry." When they go on "wet" that's when they will attack the foam. If in doubt, test spray paints on some scrap foam.
Some people use water-based polyurethane as a base coat before painting and Future floor polish after painting to protect the finish.
- Jeff
jdetray is offline
Old 08-27-2010, 03:31 PM
kmorselander
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jeff, my problem has been using tape to mark off lines.  All the painters' tapes I have applied remove paint from foam.  Any suggestions?
kmorselander is offline
Old 08-27-2010, 04:34 PM
jdetray
jdetray's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I suggest you read this thread, which is all about painting and finishing foam planes.
[link=http://www.rcgroups.com/forums/showthread.php?s=&threadid=161218]How I Finish My Planes- Step By Step[/link]
The author of the thread is one of the masters of foam plane building and finishing. It is a fantastic thread.
- Jeff
jdetray is offline
Contact Us Archive Advertising Cookie Policy
