What Happened to "Club Saito"?
Banned
RE: What Happened to "Club Saito"?
good..however I have not yet made the code changes. I think as I said I know what it is and why it is "flapping". After the database server issue last night I still have to setup a test databsae so I can try it before pushing live on site to be safe....hopefully tomorrow as long as nothing else pops!
Banned
yes...I'm going to have to put this off until after the holidays so I can be around to test it on live site in case something goes wrong I need to revert back. probably tuesday sometime.
#32
OK
Ok Tom
I've installed the header pipe on the saito 180 and with the combination of the header port and the crank case pressure together it will fly and run nicely. But I would like to ask you if anyone has ran this motor with a regulator style pump successfully yet, it is a little slow to respond in the lower range, and I know that the pressure is lower at lower speeds so that's the reason. But I here that the sintrifical pump isn't the sure fix. Any suggestions? Jason
