E-flite camera
I just purchased an E-flite EFC-720 HD camera. Since I will be putting it on a float plane I soaked it really good with corrosion-x. If my plane ever goes for a dunk then I want it well protected. My problem is the corrosion-x has fogged up the lens, any suggestions on how to clean it? I thought of rubbing alcohol on a q-tip but I'm not sure what the lens is made of and this method could damage it. Any suggestions?
Most of us use Rain-X anti fog to coat the lens, Corrosion-X works ideally on pcb circuit board but not on the glass lens.
Thanks! That's also what I need!
