FPV Equipment Talk about equipment used for First-Peson View Flying.
5.8G Two antenna Video Receiver 64 Channels with Digital LED Display DVR
Reply
Old 03-29-2019, 04:47 PM
Long-Day
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 5.8G Two antenna Video Receiver 64 Channels with Digital LED Display DVR
Receiver Specifications:
Model:DIV006 V4(DVR)
DVR Function:DVR with auto save function
Working Voltage:7-26v
Power Consumption:12V,210mA
Channel:64CH (RaceBand)
Format:NTSC/PAL selectable via menu
Sensitivity:=-95db
Channel Selection:Digital Display, Single Button Selection, Auto Scan, Diversity
Antenna Connector:SMA- Jack (outer thread, inner hole)
DIV006 Features:
DVR recording audio and video signal simultaneously in D1 resolution.
AV out:640x480
Video compression format:MJPG
TF card slot, support to 64GB
Recording file format:AVI
Playback available
PAL/NTSC selectable via menu.
48CH selection by single button, digital display current channel#.
Single short press button to change channel from CH1 to 8 and buzzer beeps while each press; long beep indicates on CH1.
Each time long press 3s to change band from A to H.
Digital tube point indicates which antenna is selected to work.
Receiver Accessories:https://pt.aliexpress.com/store/prod...7fa41d7aETvLCv
1x5.8G A/V Receiver
2x5.8G antenna
1x1.2m, 3.5male/RCA male AV cable
1x1m, 2.1*5.5male/bare tin power cable
​1x30cm, 3.5male/RCA female AV cable
Long-Day is offline
