Hubsan X4
I think you should get way more than 20-25 flights. I've had mine for several months now and over 50 full battery flights, no problems with the motors. Check out some replacement parts, not that expensive on Amazon (~$15).
It's possible that you crashed it one too many times. Also, its easy to get hair stuck in the rotors. Prop them off and clear of debris and then try again. Good luck!
