Has anyone messed with the Fatshark Telepoter V5 goggles yet
IN
Has anyone messed with the Fatshark Telepoter v5 goggles yet an had any problems with them. the set I have now is a replacement set from get fpv as id the fatshark 700 tvl cmos cam. I am using well tried a fatshark 250mW and an immersion 600 mW Tx everything is hooked up correctly both Tx are getting power as are goggles. Have tried 2 different cams an all channels on headset an still get all white fuz am using a Fatshark voltage regulator 1300 mAh battery an providing power to fpv gear vir balancing plug to regulator have tried everything including dip switches on bottom of Tx on both of them to try different channels everything is plugged in an seated fully no lose connections an all wires are running the right way 1st cam from fatshark was missed pinned from the factory if anyone has any input feel free to chim in on this one.
