Unmanned flying wing "ATLAS-2"
Friends Hello!
I want to introduce you to an unmanned aircraft project constructed by composite technologies.
The characteristics of the aircraft, which want to receive.
- Flight time is 1 hour 30 minutes.
- Flight range of up to 25 kilometers.
- Automatic takeoff, flight.
- Automatic landing by parachute.
- Electrical engine.
- Flight weight up to 5000 grams.
- Wingspan 1800 mm
PAYLOAD :
- Thermal on a stabilized platform.
- ZOOM 27x camcorder on a stable platform.
- Wingspan 1800 mm
PAYLOAD :
For aircraft designed internal components.
I will prepare the details of light plywood in order to reduce weight.
The spar cut out of foam sandwich + carbon.
Flight To weight 5300 grams, on an airplane wing load is equal to 76 grams per decimeter
After painting I cut a laminate of foam Herex 1,2 mm.
Correct form foam can be an industrial hairdryer.I have done in two steps. First, the outer layer of fiberglass 50 g / l and HEREX, and the second phase of the inner layer of glass 25 g / l and back under the film.
___________________________
