does the dx5e have the same output power as dx6i? reg: range boost.
AZ
I am planning a quick medium range fpv setup and came across a cost effective means to medium to long range FPV.
well my question to you all firstly is: does the spektrum dx5e have the same power output as the modules inside of the dx6i transmitter?
I ask this because if this is true then a cost effective way to increase range is to simply use a booster to the antenna output port in the SMA output inside of the radio and use an 8 to 11 dbi patch antenna. depending on the type of beam length which is desired keeping in mind i will probably go with 8dbi for more area coverage. This would be perfect for me since I FPV without the extra channel on the dx6i and dont need the expo since I am using a glider and not 3d.
so does anyone know? if the module/modem unit inside of the dx5e is the same as the dx6i in terms of output power? I also say this is because they advertise that dx5e is a FULL RANGE TX just like their other models of radio transmitter.
thank you for your time and help in advance.
RE: does the dx5e have the same output power as dx6i? reg: range boost.
Hi,
Yes, the power output level is the same for the DX5e and DX6i transmitters. Only the Spektrum receivers are designated Parkflyer or full range.
I have all the Spektrum transmitters and a JR 9503 transmitter.
You can read more [link=http://spektrumrc.com/Products/Default.aspx?ProdId=SPM5510]here[/link].
Good luck!
Good luck!
