7C : down trim with flaps
[] I spent an hour last night in the manual trying what I thought would allow Down elevator trim when I use landing flaps. No luck so far. I have the flaps on the two step switch on Right top using two settings of down flap and would like a automatic down trim added to elevator with each step of flaps applied...What am I doing wronge? Please help...(Radio is a 2.4 7 C..........great radios.......thank you, Terry.
[email protected]
[email protected]
RE: 7C : down trim with flaps
I am doing this very thing with a 7C. I am using channel 7 for flaps on switch G like you. I use a P-Mix and make 7 the master and 2 the slave. You can assign switch G or if you only want a mix on full down flaps leave the switch unassigned and turn the mix on. You will have to use two P-Mmixes if you want different amounts of elevator trim for the two positions down. I only use elevator trim in the full down position so I am only using one.
OK, you can do it that way. We were thinking that using a mix could cause difficulties in two of the positions of the 3-position switch. Since there's only ways to set endpoints, and not follow the flap application directly, the 7C's mixer would not be particularly-good about it. You can use two mixes, but the downside is that you're using TWO mixes.
I have tried a few things since we were on this subject. You can assgin switch G and you have actually about 4 choices. You can have mixing only in the up position or the down position, and also in the down and middle position or in the up and middle position. It seems to work well. You have to try it and put in the percentage you want and it depends on the whether the elevator is reversed or normal as to whether you put - or + percentage in. I'm usuing it on about 3 different aircraft and I ususally use between 6 to 10 percent. You can also leave the switch unassinged and it only works in the up position for me. Which in my case is full down flaps.
