6 volt vs 4.8 volt receiver supply
My Feedback: (33)
MA
I have a quick question. I am building a TF AT6 Texan. One thing I am considering is the power supply for the receiver. Why or when would I use 6 volts for my FASST instead of 4.8 volts? Might seem like a silly question but no one seems to agree on an answer. This is my first big plane after a trainer and low wing. Someone recommended two 1000 mAh, 4.8 volt batteries in parallel when anotheer suggested the 6 volt option. Looking for some advice and knowledge from the pros!
CA
RE: 6 volt vs 4.8 volt receiver supply
Hey Pangi.
You will get a few different ideas from different people here. I can only tell you, the system that I would recommend for you. I would run two A123 batteries using two switches both connected to your receiver. Your servos provide more torque and faster speed when connected to a 6 volt system, rather than a 4.8 system. The A123 technology is the way to go in my opinion. I would run two batteries with two switches.
Go to http://www.hangtimes.com/a123_batter...iants_faq.html and do some reading. There is a lot of good information here. Spend some time reading this stuff. Educate yourself on what to use.
Hope this reply helps you!
Mike
Mike
A receiver can handle either. The servos are what you need to be concerned about. They are what determines your system voltage. Servos on 6.0V are a bit faster and stronger, but may not have as much service life. Some servos just can't take 6.0V at all.
