Futaba 8 Channel Receiver Question
I am now using Futaba R6008HS receivers with A123 6.6V LiFe batteries and digital servos. This setup has performed flawlessly. I just noticed Futaba has a new "High Voltage Receiver" the Futaba R6208SB 8-Channel 2.4GHz FASST Hi-Voltage Rx. This "High Voltage" receiver has the S-Bus feature which I don't plan to use. My question is, does the the R6208SB have all the functionality as the R6008HS? Would there be any advantage offered by the R6208SB?
Thank you
J.C. (FASSTFLIER)
Thank you
J.C. (FASSTFLIER)
RE: Futaba 8 Channel Receiver Question
Hi JC,
This receiver has all the functionality of the R6008HS, it is full range, it has High Speed mode, can be used with either conventional, digital or S-Bus servos, and it has of course the S-Bus port.
Here is a link to the manual for the receiver:
http://manuals.hobbico.com/fut/r6208sb-manual.pdf
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
Sincerely,
Krysta
[email protected]
