Floating Aileron Servo's
My Feedback: (13)
Sir,
I have been using the same 6EX TX and R617FS RX radio system for the past two years without any problems. Just recently I have been having problems with my ailerons not centering in the right location after power up. I have reset them and it would be fine until I either moved the aileron stick on my TX or shut down the system and power back up. This problem has showed up on two different airplanes using the same TX. One plane has a mirical "y" and the other is set up wuth a normal "Y" connector. Do I have a bad TX or power issue to the servo? Any help is appreciated.
RE: Floating Aileron Servo's
I've seen the same behavior in some of my older airplanes with the aileron servos. It seems to stem from a slightly dirty or corroded pin/socket in the connectors. I'll bet that if you plug/unplug the connectors several times, essentially "wiping" them clean, this "floaty, bouncy" behavior will go away. This has been my experience. It is not a receiver, transmitter, or servo problem.
