12 fg programming question
RE: 12 fg programming question
3 conditions on a 3-way switch are easy. When you set up condition #1, it's on no switch. I put condition #2 on SA, and the on/off position of the switch is "off-on-off". I put condition #3 on SA, and the on/off position of the switch is "off-off-on". Now, when I move the switch to one extreme, condition #1 is active. Switch in middle position gives condition #2, and switch at the opposite extreme give condition #3.
If you have additional conditions, and want them on a 3-way switch, then condition X will have the switch "on-off-off", condition Y will have the switch "off-on-off", and condition Z will have the switch "off-off-on". Done.
Bax
I tested the configuration reported by you and it works as expected for the switches SB, SC, SE and SG. But for the SA and SD not work. The condition #1 is never activated when the switch is moved to the position indicated, running like condition #2.
I noticed this behavior after upgrading the firmware to veresão 3. Is there any fix for this situation?
