10c flap/elevator mix
I have various aircraft where the flapsare assigned toa 3 position switch on my 10c t/x.
When I try to mix elevator with the flap positions I can only mix it with the flap full down, not centre position.
How do I mix elevator trim with both down positions?
Also how do I set the range for the central position, I can set the full down ok.
Flaps are y leaded together on Channel 6.
Thanks Darryl
RE: 10c flap/elevator mix
The best way to do this is, instead of trying to mix your Elevators to your Flaps, do two separate offset mixes on your Elevator.
Make the first as Offset Master, Elevator slave, set the percentage to what you want them to move and then set this on the same switch as your flaps and set them in the Center position.
Do another mix the same way, but change the rates and then set this in the Down position.
This should have you having both Elevator and Flaps on the same 3-way switch, in the Center the Elevator will move to the first setting, in the Down position it will move to the second setting along with your flaps each time.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
Sincerely,
Krysta
[email protected]
Thanks Krtsta.
i will give this a try.
The 10c must be one of the best t/x's available on the market, but the lack of instructions in the manual to do the most basic tasks rates it along with a basic t/x set.
many thanks
Darryl
many thanks
Darryl
