Futaba 14Z and Thunder Tiger MiniTitan 325 SE
CA
I was given a set up for my Thundertiger Raptor 50 for the Futaba 14Z which is fantastic. I have tried to set up my own set up for my new Thunder Tiger MiniTitan 325SE. The set up is ok, but I am not quite sure how one sets up different conditions such as IDLE-Up. I have created the conditions. I have set a switch to set the condition. But it doesn't seem to really have done it. When I attempt to change the throttle curve in IDLE-Up it changes it in both conditions. The conditions have not somehow separated.
Does anyone have a more complete explanation of how to set up conditions?
Does anyone have a set up for a Thundertiger MiniTitan 325SE?
If someone has a good setup for a Thundertiger MiniTitan 325SE for a Futaba 14Z radio, could they email it to me?
Thanks.
Art Wallace
[email protected]
Thanks.
Art Wallace
[email protected]
RE: Futaba 14Z and Thunder Tiger MiniTitan 325 SE
When you set up a control function, mix, rate, and so forth, you need to turn on the desired condition, and then set the rate or function, in this case, the idle-up, to SINGLE. That makes that particular setting local to the condition. Otherwise, it's global.
CA
Thank you, that is very helpful. Does Futaba have a library of close to correctly set up aircraft and helicopters for download? I found a site that had all the downloadable set ups for Spectrum for a number of aircraft, it would be helpful to have examples that could be modified rather than starting from scratch.
