wrapping rx's
My Feedback: (204)
wrapping rx's
Hello Bax or Krysta, I just mounted a 14 ch rx without wrapping it in foam, just sitting on a piece of foam, I then mounted a 7 ch rx (617) totally wrapped in foam. I'm reading from some articles that it's not a good idea to completely wrap 2.4 rx's in foam like we used to, has this been an issue?
Thanks for any input
Frank A Rega
Frank A Rega
RE: wrapping rx's
You may or may not. People just aren't protecting receivers like they used to do. That's for two reasons...1) they just aren't due to the fact that it's easier to tie it down and use less space, and, 2) Modern receivers are better at resisting vibration due to the large amount of surface-mount components. However, it's still a good idea to give your system as much protection against vibration and impact as possible.
Some early 14-channel receivers had a difficulty when they were allowed to become hot under a canopy in direct sunlight. Those receivers that were foam-wrapped would absorb and retain that heat. Eventually, they could become hot enough to quit. None of the current-production receivers have heat-related concerns, so if you want to use foam rubber to help insulate your receiver against vibration and impact, go ahead.
It should be noted that a small foam pad under a receiver with a tight strap of velcro-type tape holding it in really doesn't give much protection of any kind. When it's tightly-strapped into the model, the strap compresses the bit of foam and most of the insulation is gone.
