Help Will my Campac from 9c super Work in a 10c
RE: Help Will my Campac from 9c super Work in a 10c
Well, the CamPac will work, but if you don't want to lose anything on it, don't allow the 10C to format the CamPac. Just copy the models you want to use into the 10C. That will leave the memory in the CamPac intact, and you'll still be able to use the CamPac in your 9C transmitter.
Of course, if you don't care about what's stored on the CamPac, then let the 10C format the CamPac, and you can then save models in 10C format to it. However, it will no longer work in the 9C as-is. You'd have to do a format for the 9C, and you'd lose everything on it.
