Futaba S9072SB replacement gear set
1 Post
Hi TEch support,
can you please advise which gear sets are suitable for replacement gears for the S9072SB. I have looked at the Futaba-RC website and no parts are currently listed. i urgentl need replacement gears for this servo.
RE: Futaba S9072SB replacement gear set
We are not aware if these are sold as a complete set from any retailer, but you should be able to purchase the gears individually from your closest Futaba Distributor or from us directly by calling 217-398-8970 opt 2 or by faxing at 217-398-7721.
HSP79677 1ST GEAR S9151
HSP78391 S9451 2ND MTL GEAR
HSP78392 S9451 3RD MTL GEAR
HSP78384 S9350 FINAL GEAR ASSY(S9251 M3)
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
Sincerely,
Krysta
[email protected]
1 Post
Thank You very much. This is very helpful information. I'll contact my local distributor and present the information.
All the best
1 Post
Hi Krysta,
I've received a gear set from my local distributor but its the S9451 gearset. They have it listed as a S9451/S9072SB gearset. This seems at odds with the information posted above. Can you confirm these are the same gearsets please.
1 Post
I have fitted the S9451 first gear. It works. I've checked the rest of the gears and it appears that the S9451 gearset is the correct replacement gearset for the S9072SB.
Thanks for steering me in the right direction. Thumbsup
