Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Great Planes/Futaba
Failsafe Question
Old 11-29-2012, 06:37 PM
OldCoot
My Feedback: (47)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Failsafe Question
T8FG with R6008.
I have a Quad rotor copter with Naza controller. I cannot get the Naza to recognize a fail safe when I turn off the transmitter.
In order for the Naza to see a fail safe, at least one of the channels must loose servo pulse. Am I correct than when the R6008 looses TX signal it still maintains a pulse to the servos depending on my fail safe settings (either hold position or move to F/S position).
If I am correct, is there any way to prevent the R6008 from pulsing the servos if TX signal is lost.
Dan
11/30/12 Update:
I found a workaround to get the NAZA unit into failsafe. I had to program a force failsafe switch and then set my radio failsafe to move the channel to that switch position when loss of signal occurs.
OldCoot is offline
Old 12-04-2012, 08:01 AM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Failsafe Question
We are not familiar with a NAZA controller. With Futaba 2.4 GHz receivers, none of the servos will actually lose a signal when the system goes into failsafe. They go to predetermined positions. The 8-channel receiver allows you to set the failsafe position of every channel. If your multi-rotor system has its own failsafe system, then however you set the system to make it work would be correct.
Bax is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
