Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
14MZ Battery
Old 12-09-2012, 02:14 PM
chutt
chutt's Avatar
Default 14MZ Battery
On 14MZ manual it says:
As the internal circuit of the transmitter stays on the standby mode for 4 hours after turning off the power, some part of the circuit is consuming current.
Can I remove the battery during this period of 4 hours?
I read somewhere to not let Li-ion batteries inside radio when not in use.
Which is correct?
Let the battery inside the radio or remove the battery from radio when not in use?
Thank you,
Andre.
Old 12-09-2012, 02:25 PM
Silent-AV8R
Silent-AV8R's Avatar
Default RE: 14MZ Battery
You can take the battery out any time you like for as long as you like. Its only function if to provide power. The "standby" is a software thing sort of like a computer going to sleep. It just allows the radio to "wake up" faster when power is turned back on.
OOPS!! I did not see this was in the vendor only area. Details!! I get lost in the details.
Delete at will.
Old 12-09-2012, 03:25 PM
chutt
chutt's Avatar
Thank you buddy!
